Can somebody please tell me how to calibrate the throttle position sensor, I have the manual on cd and all it tells me is how to remove and refit same, it does not tell how to calibrate it. Sorry guys it is on a 2002 au 6 cylinder auto.
Flairs - Truckers Delight
no calibration required, it's all done by the computer
Thank you for that Mr Hardware, I had been told that I had to recalibrate it every time you disconnected the battery, that is why I came to someone that can put me on the right track.
every time you disconnect the battery, the ECU resets itself.
Thats probably what they meant. |
#5 | |||
Walking with God
Resetting of AU ECU http://www.fordforums.com.au/showpos...9&postcount=85 GK
#6 | |||
As GK said.
Are the Supercars on yet?
small question on resetting ecu. says put car in gear for a manual, i assume the clutch would have to be in, which kinda means the car is in neutral
![]() ![]() V8 dreamteam 1st: 2012, 2021 ![]() 2nd: 2015, 2016, 2020, 2022, 2023 3rd: 2014, 2018, 2019 |
#8 | |||
Walking with God
As long as the few minutes with the aircon off and on are done in a manual, it should go okay. GK
i suppose you could put it in gear with the clutch released and just idle roll down the road for two minutes
if it was 3am
All Bran = Regular Member
... in Cobar...
jack the rear wheels off the ground?
#12 | ||
Selecting drive is to let the ECU learn idle under load.
Same for turning on AC. If you have a manual, the only load under idle it needs to learn is the AC..... Cheers James |
#13 | |||
Walking with God
GK
#14 | |||
You can't stop the signal
When it says to put the car in gear, I've always turned the highbeams on.
Remeber hearing that from someone a while ago. Cheers
#15 | |||
